Hard start, start it again it acts like old carburetor with choke?
245,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BROWN DOG
First start of the day is normal but driving for a while shutting it off trying to start it again it acts like old carburetor with choke stuck, but tap the throttle it comes out of it, but jumps to 2,000 for about 15-20 seconds. The code says EGR, swapped it out still have same problem.
Jul 22, 2022 at 5:39 PM
  • 55,732 POSTS
Do we have any codes? let's use this guide to check, also it sounds like it might be a vacuum leak at the throttle body base gasket, we should service the throttle body as well. here are some guides to get us started on fixing the problem:
And check for a vacuum leak when the engine is cold.
And
Jul 23, 2022 at 3:29 AM
