Hard start
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
This car drives excellent, no issues, no malfunction messages, but if i leave it parked couple of days or so and i go start it it takes forever to start, she just keeps turning. the battery is strong but because i keep trying to start it it will discharge a bit. so i out a jumper box and jeep trying with gas pedal all he way to he floor until it starts to want to start and then it shuts off, no issues after that.
Feb 27, 2020 at 11:37 AM
JIS001
  • 3,412 POSTS
If you have a scanner I would recommend you scan for fault codes. If you do not have a code reader, most parts stores can do it for you or rent you one. If you do have one or rent a scanner then here is a link on how to retrieve the fault codes. If you have codes post them on here. Also try to get a scanner with live data as well. Keep us posted please.
Feb 27, 2020 at 1:09 PM
NASER NASER
  • 836 POSTS
Nothing except this:
Feb 27, 2020 at 11:01 PM
NASER NASER
  • 836 POSTS
finally started after having a jumper, took forever, then was in a limp mode and barely moving with brake and traction lights on, I know these lights come on when battery was drained, until the battery charges, and would not rev up, if you do it will hesitate badly and rpm jumps, got home, turned it off, started right up and all lights gone and revs normally.
Feb 28, 2020 at 8:10 AM
JIS001
  • 3,412 POSTS
The first code you posted is what you need to focus on. The scanner you have is a little more advanced so it gives manufacturers specific codes. If you can get a generic code it makes it a little easier to pinpoint the area to diagnose.
For this fault code here is what they have for possible causes from the BMW repair guide.
Condition for fault identification
 Test condition:
 Throttle valve not without current
 Driver torque demand is being exceeded
 Terminal condition: Terminal 15 ON
 Voltage condition:
 Voltage in onboard electrical system >= 10 V
Condition for fault memory entry
 480 ms
Action in service
 Check mass airflow system (vacuum leaks, VVT, VANOS,
 throttle valve...)
 If frequency is >=3 Replace DME
The first thing you need to do is have the battery fully charged and tested with a battery tester. If cranking voltage is below 10 volts then it will struggle to start. Your local parts store can do a battery and cranking test to verify battery health.
Now the test needs to be done at the battery. If they do not connect the tester at the battery then the test results will not be valid. Have the battery load tested and cranking voltage test results posted and we can proceed from there. If the battery fails then that will be your most likely failure.
Feb 28, 2020 at 3:24 PM
NASER NASER
  • 836 POSTS
Thanks. I will monitor it, it starts fine if you start it daily. I started it today and all good, will see how it goes.
Feb 28, 2020 at 10:38 PM
  • 55,694 POSTS
JIS001 is one of our best! Please let us know what you find. We are interested to see what it is.
Mar 2, 2020 at 4:44 AM
