Hard staring after sitting a while
287,000 MILES • 3.6L • 6 CYL • 2WD • MANUAL
EDWARD SMALL
After sitting for several days she is hard to start.
Turns over tries to catch and sometimes fires but very low hardly running then stops. Giving fuel does not help. This may happen two or three times and then she starts up normal and runs fine and takes the pedal when pressed.
Thanks
Sep 27, 2017 at 10:22 AM
CARADIODOC
  • 34,414 POSTS
Connect a fuel pressure gauge and see if it drops over an hour or longer. Pressure is supposed to hold for weeks. If it drops over time, suspect a leaking injector.
To verify fuel pressure is causing the problem, turn the ignition switch to "run", wait a few seconds or until you hear the hum of the fuel pump stop. Turn the switch off, wait a few seconds, then turn it on again. Do that perhaps a third time, then try to start the engine. Each time you turn the ignition switch on, the fuel pump will run for one second. Two or three seconds should be enough time to build fuel pressure high enough for the engine to start.
Sep 27, 2017 at 12:15 PM
