Hard shifting
160 MILES • 2WD • MANUAL
JUSTIN BRUCE
When the vehicle is on do you have to slam the shifter to get it in gear when the vehicle is off it goes into gear perfectly fine.
May 22, 2020 at 9:57 AM
This is because when the engine is on the flywheel is spinning and your clutch is not fully releasing the friction plate from the flywheel so there is pressure on it so it is hard to engage. When the engine is off, this is not happening so the shifter drops right in.
https://www.2carpros.com/articles/inner-workings-of-a-car-clutch
https://www.2carpros.com/articles/clutch-symptoms
I suspect you have an issue in the slave cylinder or throwout bearing which is causing the clutch not to release.
I attached a number of guides that will cover this issue a couple different times.
I suspect we are going to have to replace the clutch and when you are there, we do the slave cylinder, bearings and then bleed the system.
Let me know what questions you have after you review this material. Thanks
May 22, 2020 at 11:51 AM
