1996 Ford Explorer Overdrive
137,000 MILES • 6 CYL • 4WD • AUTOMATIC
RUTH E
I've been driving my daughter's Explorer this week while my van is in the shop. Most of the driving has been around town and the vehicle has been fine. Today I drove it on the highway (60-65 miles per hour). It drove fine on the first leg of the trip (about 26 miles). On the way home I noticed a light flashing on the dash saying "O/D off" which I assume is overdrive. I pushed the button on the end of the gear selector arm that said "O/D off/on" and could see the difference in rpm's so I left it selected for the lowest rpm's (about 2500). Then when I got closer to home and dealing with trafic lights and stop signs I started getting a hard shift when slowing up and dropping from 2nd to 1st gear. Any idea what might be causing this? I remember having the problem when we first got the vehicle about 4 years ago and our mechanic took a quick look but couldn't repeat the problem. My daughter doesn't seem to experience it but she does very little highway driving. Thanks for your help!
Aug 1, 2010 at 11:49 AM
  • 110,246 POSTS
If the light was on, there should be a code set in the computer. You need to have it scanned to identify where the problems are coming from. The hard shift sounds like a shift solenoid; however, the over drive is a different story.
Have that done and let me know what code they find.
Aug 1, 2010 at 2:24 PM
