Hard reboot for ecu needed possibly?
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JESSS
  • 6 POSTS
Installed used engine, changed spark plugs, wires, dist cap, rotor, air filter, fuel filter, Mass Airflow Sensor, EGR, O2 Sensor
No vacuum leaks.
Check engine light still comes on intermittently reading lean bank one.
Is there a hard reset for the ECU I should perform specific to my car to stop this so I can pass smog?
Jan 19, 2026 at 8:52 AM
  • 55,649 POSTS
Yep, you can try a hard reboot, here is a video to show you how.
https://www.youtube.com/watch?v=INiDRO5A5MY
Is there any intake or exhaust leaks, these both can cause a lean mixture, here is a guide to help.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
This video will show you how to check for vacuum leaks.
https://www.youtube.com/watch?v=LRKWV4Are5c&pp=0gcJCYcKAYcqIYzv
Please upload a short video with the engine running in your response, so I can see what's going on. Please go over these guides and get back to us.
Jan 20, 2026 at 1:44 AM
JESSS
  • 6 POSTS
Thank you for your help. I go to my mechanic tomorrow. They checked already and said there are no vacuum leaks. I will let the look at it again and when I pick it up after they clear the codes again I will drive it like the manual says when it's new so the ECU learns correctly because I put a used like engine in it.
Jan 20, 2026 at 10:37 AM
  • 55,649 POSTS
An exhaust leak will cause this as well. When you say I replaced the fuel filter, was it the fuel filter inside the gas tank?
Jan 21, 2026 at 1:03 AM
JESSS
  • 6 POSTS
No it was the external fuel filter that is under the hood.
Also, I watched your video and bought the little wire with alligator teeth. They sold me a set that has two separate wires one red, one black with teeth. Can I use one of those to attach to the positive and negative to drain the car like you did?
Jan 21, 2026 at 3:48 AM
JESSS
  • 6 POSTS
Mechanic is not available until tomorrow so I want to try to drain and then relearn my ICU to my cars specific pattern in the manual like you said.
Jan 21, 2026 at 3:53 AM
JESSS
  • 6 POSTS
Do you think I should wait to do that until after the mechanic has it for a day to see if they can find any exhaust leaks or anything else.
Jan 21, 2026 at 3:55 AM
  • 55,649 POSTS
Yes, I would wait until the mechanic looks at it.
Jan 23, 2026 at 12:41 AM
JESSS
  • 6 POSTS
Hi Ken,
Do you have a phone number I can call you at? I really need your expert opinion. I just picked my car up from the mechanic and wanted to go over what he thinks. My number is 805-276-6834
Jan 28, 2026 at 4:03 AM
  • 55,649 POSTS
We cant make calls, can you explain here what is going on?
Jan 29, 2026 at 12:53 AM
