Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Am
Engine
Vacuum Hose Diagram
hard plastic vacuum line
2000 PONTIAC GRAND AM
235,603 MILES • 3.4L • V6 • FWD • AUTOMATIC
NMILES
MEMBER
1 POST
On my upper intake have a vac port connected to a plastic vac line that run in the wire harness where is this line for and where does it go
Mar 21, 2016 at 8:31 PM
Experienced Mechanic
More than likely this is a line that runs from the EVAP to the intake or the intake to the PCV.
Here is a guide that will help with finding vacuum leaks if you need to find one:
Please see the info below which is a diagram that shows the routing of these lines.
Let us know what other questions you have. Thanks
Image (Click to enlarge)
Oct 26, 2021 at 12:39 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
