Hi Guys,
First-time poster here, having problems starting the car.
1. Bought it a year ago. Did plugs, wires, cap, K&N air cleaner, fuel and oil filters, water pump (weep holes leaked as soon as I got it.) MSD coil.
2. Recently, I have been getting hard/no start conditions. The engine cranks no problem. Battery is new.
3. Fuel system - I have been getting consistent 56-58 psi with key on but engine not running. This is with the old fuel pump, and the new one I installed yesterday. Today I got 58 PSI with no run and 52 psi while running. I replaced the CFSI spider last year. I got the upgraded electronic one. I also replaced the fuel filter again yesterday. I also swapped out the relay. Fuel pressure regulator, as I am sure you are aware, is integrated into the spider.
Question: If the fuel PSI is supposed to be 60-66 psi, and I replaced the pump, filter, and spider, why am I not getting the correct PSI? Oh, I have a new gas tank cap as well.
4. Could this be a MAF/TPS/CPS or other problem?
Any help would be greatly appreciated. Winter is coming, this is a new problem. oh, and the car runs fine otherwise when it is running, it is not a problem.
Many thanks,
Maitai
Many thanks,
Maitai
Nov 27, 2017 at 8:52 AM
