My van started sputtering and idles hard. I haven't drove it in a week now have light ticking noise in engin.
Sep 15, 2014 at 4:23 AM
✓ASE Certified Mechanic
Is the noise only at an idle? Have you checked the oil level? Have you checked for vacuum leaks and the idle air control valve? Has the check engine light come on?
Sep 15, 2014 at 5:24 AM
REDFOX17
MEMBER
The ticking noise increases when I touch the gas pedal, oil level and vaccum leaks along with idle air control are being done now. But as far as the check engin light it has never came on.
Sep 15, 2014 at 10:24 AM
The vacuum leaks or IAC could cause the bad idle, but not the ticking. You may want to check oil pressure using a mechanical gauge to see what it is.
Sep 15, 2014 at 6:15 PM
