I have a 2007 Honda Pilot and the gas pedal does not have much give, only about an inch and when I press the gas it goes but slowly.
May 4, 2015 at 1:04 AM
HMAC300
✓Experienced Mechanic
check for interference like carpet or something else in way then have a pro check to see if the electric unit is bad or going bad as the gas pedal is electric now. it may throw a check engine code as well.
May 4, 2015 at 2:44 AM
KLUNA1210
MEMBER
Thanks so much for your response but there is no obstruction that I can see. My mechanic only drove it and thinks I need a transmission flush but I don't know if that will fix this
May 4, 2015 at 3:14 AM
HMAC300
a transmission flush will not help a gas pedal problem if it is truly that. If it's a trans problem then that is something else entirely. If the gas pedal moves freelylike with engine shut off then it may be a trans problem like a slipping clutch pak or something like that I'd have a trans guy look at it .
