Hard engine knock
102,848 MILES • 3.0L • V6 • 2WD • AUTOMATIC
LYON022
I have the car listed above with a 3.0L 24V Duratec engine. I have changed the spark plugs and it is full of oil. There is a bad engine knock coming from what I believe is cylinder 2. I believe it could be a rod knock due to bad bearing because I drove it too hard. I just need a second opinion before I start taking the car apart to figure out the culprit.
Nov 13, 2019 at 4:46 AM
Good afternoon,
The fact you have oil in the cylinder tells me you have more of piston damage than bearing damage.
Can you upload a video of the noise so I can hear it? That will let me make a better opinion.
Nov 13, 2019 at 7:05 AM
LYON022
Oh well, I can get a recording of the sound give me some time on that. Thanks for the information. I'll be back to get the knocking sound.
Nov 13, 2019 at 7:11 AM
Sounds like a plan.
We will be waiting for the video.
Nov 13, 2019 at 7:12 AM
LYON022
Good morning. I have the video for you. Hope it helps.
Nov 13, 2019 at 10:46 PM
You have either a broken piston, bad bearings or some other failure.
The bottom line is, you need a motor. You can either get a used motor or a rebuilt motor depending on what you want to spend.
Nov 13, 2019 at 10:57 PM
LYON022
Thanks for the second opinion.
Nov 13, 2019 at 10:59 PM
You are welcome.
Always glad to help.
Nov 13, 2019 at 11:12 PM
