Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Silverado
Drivetrain
Drive Shaft
Center Support
How much play is acceptable or normal from the robber in a hanger bearing?
2000 CHEVROLET SILVERADO
130,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
MRTDS
MEMBER
A new hanger bearing was just installed in my truck listed above and the play is about 1/4 to 1/3 inch. See attached video. Is this normal? Thanks.
Video (Click to enlarge)
Dec 3, 2021 at 2:28 AM
Experienced Mechanic
That's a good question. To answer, yes that is normal. The bearing itself is mounted in rubber, so there should be movement.
Let me know if you have other questions or need help with anything.
Dec 3, 2021 at 11:38 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
