Handbrake emergency brake while driving
19,000 MILES
SALMAN RAHMAN
Hello, I bought a car to learn in. It is a manual car with handbrake. While driving when the teacher pulls up the handbrake it just slows down the speed until it stops. Do I have to turn off ABS or something? It is really important for us that it works exactly when the handbrake is pulled so we don't crash into anything.
Sep 14, 2019 at 6:36 PM
  • 110,251 POSTS
Welcome to 2CarPros.
First, this model isn't offered in the US, but I will try to help.
The hand brake and ABS are two separate components. The hand / parking brake is an adjustable component. On most vehicles, the adjustment is done at the brake lever. However, the actual parking brake shoes may require adjustment as well.
Since this vehicle is very similar to the Hyundai Elantra, which is offered in the US, I will provide the directions for adjustment which should be very similar.
__________________________________
Here are the directions. The attached pics correlate with the directions so confirm the parts are the same.
2009 Hyundai Elantra L4-2.0L
Adjustments
Vehicle Brakes and Traction Control Parking Brake System Parking Brake Cable Adjustments
ADJUSTMENTS
Adjustment
Parking Brake Shoe Clearance Adjustment
Disc Brake Type
1. Raise the vehicle, and make sure it is securely supported.
2. Remove the rear tire and wheel.
3. Remove the plug from the disc.
4. Rotate the toothed wheel of adjuster by a screw driver until the disc is not moving, and then return it by 5 notches in the opposite direction.
pic 1
Drum Brake Type
1. Depress the brake pedal several times to set the self-adjusting brake.
NOTE:
For Drum Brake type, shoe clearance is automatically adjusted by the adjuster and adjusting lever.
Parking Brake Lever Stroke Adjustment
2. Remove the floor console.
3. Adjust the parking brake lever stroke by turning adjusting nut (A).
Parking brake lever stroke :
7 clicks (Pull the lever with 20kg)
NOTE:
After repairing the parking brake shoe, adjust the brake shoe clearance, and then adjust the parking brake lever stroke.
pic 2
pic 3
4. Release the parking brake lever fully, and check that parking brakes do not drag when the rear wheels are turned. Readjust if necessary.
5. Make sure that the parking brakes are fully applied when the parking brake lever is pulled up fully.
6. Install the floor console.
Let me know if that helps.
Sep 15, 2019 at 11:23 AM
