Hand Break cable
200 MILES • 1.8L • 4 CYL • FWD • MANUAL
ANGIEEE
  • 37 POSTS
After pulling my hand break up , i felt something release.I think the cable snapped.I live in Australia.I know they have 3 cables but do you know... labour and price wise i will pay to have all 3 cables replaced.Also is hand break for the back wheels or does it work for all 4 wheels.
Mar 25, 2016 at 11:42 AM
CARADIODOC
  • 34,415 POSTS
The hand brake is for the rear wheels.
We don't get involved with costs here because there's way too many variables. You can get an idea of the wholesale cost of parts by visiting the web site for a local auto parts store. You'll pay more for the parts at the repair shop because they mark their cost up just like at any other store, then they take on the responsibility for getting them delivered, if they damage one or get the wrong part, etc. Also, if a new part fails, they cover the labor cost to replace it a second time.
Typically most repair shops charge labor according to a "flat rate" guide. Those list the number of hours for each procedure for each car model and year. That way every shop quotes the same number of hours. Only their hourly labor rate varies. The lowest labor rate isn't always the best value, so don't use that when selecting a shop.
Mar 25, 2016 at 1:08 PM
ANGIEEE
  • 37 POSTS
thank you ..but do you about how many hours does it take....roughly ?
Mar 25, 2016 at 1:26 PM
CARADIODOC
  • 34,415 POSTS
Nope. Some European imports can take all day. On some cars, especially those with rear disc brakes, the two rear cables take a few minutes for each one because the rear brakes don't have to be disassembled. That might sound nice now, but you pay for it later when those brake calipers have to be replaced. They're REAL expensive.
Any shop should be able to give you an estimate without seeing the car, but you have to understand there may be other related things they'll run into that they had no way of knowing about, so be prepared for surprises.
One of those surprises is when they take the rear brakes apart, if necessary, and they find the linings are worn to the point they need to be replaced. You may end up with a standard rear brake job. A conscientious mechanic who has your best interest at heart will also inspect the front brakes. Those are supposed to wear out about twice as fast as rear brakes. Some mechanics think they're looking out for your wallet by only doing what is needed right now, and they don't look any further. In reality that usually does you a disservice by not finding things that are going to cause a problem soon.
Given the age of the car, rust is going to be a factor, and for that many shops throw out the flat rate guide and charge strictly according to the actual time it takes the mechanic to get rusty parts apart and replace broken fasteners. Flat rate times don't take rust or age into consideration.
Most front cables are considerably more difficult to replace than the two rear ones. They go through the firewall or floor and have to be attached where it is hard to get to.
If I had to replace all three cables on my '88 Grand Caravan, I know I could do it in a few hours and wading through tons of rust, while sitting in my driveway. Your front cable will attach to the handle between the front seats, and that requires disassembling a lot more stuff. To be safe, I would plan on an afternoon to complete the job. If you're told to leave the car for an entire day, I guess I wouldn't be real surprised.
Mar 25, 2016 at 2:28 PM
