had to replace belt on alternator?
177,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BRANDYBMB78
  • 12 POSTS
can someone please give me the exact wiring diagram for the alternator starter and battery?
Apr 30, 2024 at 7:17 AM
  • 110,248 POSTS
If you look below, there are two wiring schematic pictures. The first one is for the charging system and the second one is the starter (automatic transmission). Take a look at them and let me know if they help.
Also, let me know what is happening. I should be able to help.
Apr 30, 2024 at 12:08 PM
BRANDYBMB78
  • 12 POSTS
recently had to put belt back on the alternator and now car acting crazy lights flicker hardly no power when put in gear and mash gas.
Apr 30, 2024 at 10:42 PM
  • 110,248 POSTS
When you say the lights are flickering, do you mean things like the headlamps or are you referring to the cluster warning lights?
Do me a favor. I want to know what the alternator is doing. Here is a link that explains how to test one. It is very easy and only requires a voltmeter or multimeter.
Check that and let me know the results.
May 1, 2024 at 12:39 PM
