White smoke, lacking power
20,000 MILES
KOGAN NAICKER
Getting white smoke whilst driving, no power. What are the possible causes?
Jun 29, 2020 at 12:27 AM
Good morning,
Sounds like you are burning coolant from a possible failed head gasket.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
You need to do a leak down test on the cylinders one by one. Remove the spark plug or injector if you have a diesel and air up the cylinder with shop air. Then with the radiator cap removed, look for any coolant movement. If there is any movement, then that is one of the cylinders that has the leak.
Jun 29, 2020 at 12:58 AM
KOGAN NAICKER
Not coolant, i ran the engine without water. It's lacking power, will do a compression test to confirm worn cylinders.
Jul 1, 2020 at 5:38 PM
Sounds like a plan.
Keep us updated.
Jul 1, 2020 at 8:39 PM
