Gwm 2.2 fuel injection
2007 ALL OTHER MAKES ALL OTHER MODELS
132,000 MILES • 2.2L • RWD • MANUAL
BERNARD 56
Good day, the gwm engine is a 4y engine can anyone please help me? when I drive constantly for about 5 km at 60 km the motor sound like it is running on three cylinders and then the motor will stall. If I try to start it again it sounds like a engine with no timing belt. if it starts again it is idle rough and then suddenly it is all fine again. please I need help!
Nov 18, 2016 at 3:58 AM
HMAC300
  • 48,601 POSTS
if you can scan for codes and check fuel pressure then do that first in US auto parts rent gauge for fuel pump. I am assuming this is a GM engine . see link.
Nov 18, 2016 at 4:17 AM
