When I first start my truck, it makes a gurgling noise?
122,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
RANDY68
It seems like from dashboard after driving a while it quits.
Dec 17, 2022 at 1:23 AM
  • 55,732 POSTS
It could be the A/C drain that is clogged but it can be also air trapped inside the heater core. Here is a video that shows you how to find and unclog the drain and if that is not the problem start the engine and allow it to get hot, turn the heater on high-speed hot temperature and raise the rear of the car up which should force the air out of the system.
https://youtu.be/q9_MZiS2_NE
and
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please go over these guides and report back.
Dec 17, 2022 at 5:36 AM
