Gunk on serpentine belt
143,000 MILES
CHARLIE JACKSON1234
There is so much gunk around my belt.
Feb 5, 2020 at 10:12 AM
Good evening,
It sounds like you have an oil leak.
Can you upload some pictures of the belt area so I can see what you see?
Are there any codes set in the ECM?
Feb 5, 2020 at 11:31 AM
CHARLIE JACKSON1234
Those are the only ones I have right now. I hope you can see them clearly.
Feb 6, 2020 at 2:12 AM
You have a bad leak up there. You should have someone clean the front of the motor off with a high-pressure soapy water and determine the source of the leak.
Feb 6, 2020 at 4:01 AM
CHARLIE JACKSON1234
Ugh! thank you.
Feb 6, 2020 at 7:55 AM
You are welcome.
Keep me updated.
Feb 6, 2020 at 9:08 AM
