Gauge problems and radiator
129,000 MILES • V6 • 4WD • AUTOMATIC
GORDO30
Well my water gauge stays 160 and battery goes up also when i turn off my car the radiator fan keeps on for about ten minutes. i changed coolant temperature sensor and check engine turned off but still gauges go weird and my A/C stared blowing hot air,
But they game me a sensor for a two wheel drive and mines a four.
Jul 4, 2019 at 9:07 AM
  • 55,721 POSTS
2wd or 4wd should matter on the sensor. can I ask if the cooling system (radiator) is full? IT sounds like it is overheating. If it is low on coolant here is a guide to help check it:
https://www.2carpros.com/articles/car-is-leaking-coolant
Jul 5, 2019 at 10:48 AM
