Grounding a wire
88,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
RANDY SHARP
  • 165 POSTS
When it says see if the PCM grounded a certain wire what does that mean and how do you check that? Thanks
Feb 8, 2016 at 12:57 AM
HMAC300
  • 48,601 POSTS
you have to check what the wire is for and whether or not the wire has rubbed through and is grounding with an engine block etc. you have to ohm test it and visually check it
Feb 8, 2016 at 1:28 AM
