Ground wire
190,000 MILES • 2.4L • 2WD • AUTOMATIC
A.HOELDT
I am trying to find out how to change a ground strap on my car. i cannot seam to find anything on it.
Feb 19, 2018 at 9:49 AM
KHLOW2008
  • 41,812 POSTS
What do you mean by ground strap? If it is the connection between the battery and body, it is a straight forward job. Disconnect the battery terminal (always remove the negative terminal first even if you are not working on it, and reconnect last) and remove the holding bolts of the cable to remove. Reverse procedure to complete.
Remember to remove key from ignition and keep door glass open to avoid inconveniences due to accidental locking of the doors when battery is being reconnected.
Feb 19, 2018 at 11:18 AM
A.HOELDT
I need to change the ground wire? Not sure where it is.
Feb 19, 2018 at 11:34 AM
KHLOW2008
  • 41,812 POSTS
If you do not know where the ground wire, why do you think you need to replace it?
There are many grounding points and which is the one you think needs replacement?
Feb 21, 2018 at 1:51 PM
