headlight, where are the dash wire grounds located?
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
MERLE720
I believe the headlight; dash wire harness has a ground issue. Where are the grounds located for that? TIPM was replaced and 2 grounds were repaired and now running into this.
Dec 29, 2024 at 11:32 PM
  • 55,456 POSTS
The ground for the headlight system is on the right shock tower. The instrument cluster ground g200 is on the left side of the dash, can I ask if the TIPM is new? If not, this might be the problem again. Do you have any codes? I would run a CAN scan which can tell you what the problem is. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Let us know how it goes.
Dec 30, 2024 at 3:27 AM
MERLE720
TIPM was rebuilt and installed by a shop.
Dec 30, 2024 at 3:37 AM
  • 55,456 POSTS
Okay, the TIPM can be bad again, did you get a chance to check the system grounds, also what kind of problem are you having? We might want to try doing a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Please go over this guide and get back to us.
Dec 31, 2024 at 3:01 AM
