Groaning whistling noise coming from the wheels
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
CABREWER
Just started. It groans at first but then fades to a whistling once I pick up speed. Sound oddly enough like some one is sharpening a knife. Does not come from the engine. Sounds like the tires.
Aug 28, 2014 at 10:56 AM
  • 110,246 POSTS
Have you checked the brakes? Have you checked wheel bearings? Have you inspected the tires for uneven wear? Does the noise change if you make a turn?
The way you described the noise, it sounds like a sensor on the brakes.
Aug 28, 2014 at 12:19 PM
