Groaning noise when car is first running?
30,000 MILES • 3.6L • 2WD • AUTOMATIC
SKOOTER28
  • 98 POSTS
Hear a groaning like noise when car is first running.
Oct 8, 2024 at 6:49 AM
  • 110,251 POSTS
Have you checked the power steering fluid level and condition? If you haven't, that is where I would start. I don't know what system you have, but it is very important to use the correct fluid type on this vehicle. Some have electric power steering and require a specific fluid.
Do me a favor. When it's cold, open the hood and have someone start the engine. See if you can tell approximatelywhere the sound is coming from. If it has an electric system, the sound will come from the lower portion of the engine's front.
I attached directions below for checking both systems.
Let me know if this helps.
Seer pics below.
Oct 8, 2024 at 12:27 PM
SKOOTER28
  • 98 POSTS
Is that what it sounds like is going on.
Oct 8, 2024 at 12:34 PM
  • 110,251 POSTS
That is certainly a possibility. That is where I would recommend starting.
Let me know what you find.
Oct 8, 2024 at 12:51 PM
SKOOTER28
  • 98 POSTS
Okay, I’ll check that first and get back with you.
Oct 8, 2024 at 12:53 PM
