Grinding while driving and braking?
240,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
TURAY206
I have replaced my brake pads, my rotors, my calipers, my CV axle, my tire rods, my front differential, and I still cannot figure out what the grinding is coming from. It’s getting worse.
Sep 9, 2023 at 10:40 AM
  • 110,251 POSTS
Is it loud enough for you to record and upload so I can hear it? If so, it may help.
As far as the noise, is there anything that changes the sound? Does it change when turning or using the brakes? Did you inspect the backing plate behind the brake rotor? Check if it is bent and rubbing the brake rotor.
Sep 9, 2023 at 3:35 PM
