Grinding vibrating noise
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
CYRUSCMG
When I drive my car at certain amounts of speed it produces this vibration that I can literally feel on my dashboard and steering wheel. There's grinding noises too.
Oct 5, 2019 at 12:53 AM
Usually, grinding noises are bearings and a vibration that goes with it would also point to a bearing.
Take a look at these guides that will help shed some light on some of these issues. Then if you can get a recording of the noise, I am be able to pick out what the possible causes are or even tell you which bearings to check. Thanks
https://www.2carpros.com/articles/vehicle-grinding-noise
https://www.2carpros.com/articles/engine-noises
Oct 6, 2019 at 8:39 AM
