Grinding tapping noise
108,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
MSZIPPL
  • 10 POSTS
when starting cold engine i hear a loud grinding tapping noise. After 30 seconds or so it dissipates. Had oil sensor replaced because it was bad. Replaced all spark plugs and oil 2 due to misfire in cylinder 2. After replacing plugs and the coil is when the noise appeared. Need help.
Jun 11, 2020 at 9:49 PM
Good morning,
Can you upload a video of the noise to this post so I can hear the noise? I need to hear what you hear.
Jun 11, 2020 at 9:57 PM
MSZIPPL
  • 10 POSTS
I can but not until later in day after it sits for 5+ hours. Only does it when engine is cold.
Jun 11, 2020 at 10:07 PM
Okay, sounds good.
Upload it when you can. I will be here to help.
Jun 11, 2020 at 10:27 PM
MSZIPPL
  • 10 POSTS
Jun 11, 2020 at 10:29 PM
You are welcome.
We are always glad to help.
Jun 11, 2020 at 10:32 PM
MSZIPPL
  • 10 POSTS
This is milder than early this morning it's the like tapping noise right at the beginning.
Jun 12, 2020 at 3:56 AM
That noise is from the lower end of the motor. There is no oil lubricating the bearings on startup.
https://www.2carpros.com/articles/engine-noises
This could be the oil pump that is draining back and the system has to prime all over again after sitting.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
You need to get this fixed as soon as you can. Each time you start it like that, you are doing damage to the bearings.
I would have someone check the oil pressure when it is cold to verify.
REMOVAL
1. Remove the oil pan and pick-up tube.
2. Remove the timing chain cover.
3. Remove the timing chains and tensioners.
4. Remove the four bolts, primary timing chain tensioner and the oil pump.
Jun 12, 2020 at 4:14 AM
MSZIPPL
  • 10 POSTS
Is it possible that it is a lifter tapping?
Jun 12, 2020 at 4:24 AM
No, that noise is too deep for a lifter.
Jun 12, 2020 at 4:33 AM
MSZIPPL
  • 10 POSTS
Would that be associated with the oil pressure sensor that was replaced 3 days ago? But why would this noise only happen after changing spark plugs and coil?
Jun 12, 2020 at 4:35 AM
It has nothing to do with the pressure switch. That just sends a signal to the ECM.
As far as the work, none of it is related. It would have happened even if you did not do the work.
Jun 12, 2020 at 4:39 AM
MSZIPPL
  • 10 POSTS
Thanks.
MSZIPPL
  • 10 POSTS
so best suggestion is to take it to Jeep dealership and let them do it?
Jun 12, 2020 at 4:40 AM
No, I would find an independent shop that can help you. They are cheaper by a long shot.
If you go to the dealer, they will tell you it needs a motor and send you to the showroom for a new car.
Jun 12, 2020 at 4:58 AM
MSZIPPL
  • 10 POSTS
This is after running at a idle which is only 500 rpm's. For 10 minutes, just up and down the long driveway.
Jun 12, 2020 at 9:26 AM
It sounds like there is no oil at the top of the motor.
Back to the oil pump as we discussed.
Jun 12, 2020 at 9:34 AM
MSZIPPL
  • 10 POSTS
How hard is it to change for someone who has some knowledge around and under a car?
Jun 12, 2020 at 9:36 AM
It is a huge project as it requires removal of the oil pan and the front cover of the motor.
The book pays over 8 hours in a shop for this. If you were to do it, it would about 3 times that time and maybe more as the timing chain has to be removed to gain access.
The steps below sound simple but are very involved.
I attached a YouTube video of the oil pump replacement for the 4.7 but is the same as a 3.7.
https://www.youtube.com/watch?v=AAj4DeFtZp0
https://www.youtube.com/watch?v=qfG4mgvWD5c
The second one is for the oil pan which also has to be removed as well.
REMOVAL
Jun 12, 2020 at 9:53 AM
