grinding sound in first gear after clutch release?
75,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
TAMBO MOBILES
  • 7 POSTS
My car is making grinding sound in first and reverse gear at little up hill or load. But gears are smooth clutch is okay and no issues in normal condition only in load it's grinding on releasing in first and reverse gear.
Mar 29, 2025 at 3:30 AM
  • 55,616 POSTS
This means the engine mounts are bad enough to allow the engine to move too much and something is contacting the frame such as the exhaust system or the counter shaft bearing have done bad inside the transmission, it will need a rebuild, sorry. I would check for excessive engine movement when under load. Please upload pictures or videos in your response of any problems so we can see what to help you with.
Mar 29, 2025 at 10:00 AM
TAMBO MOBILES
  • 7 POSTS
This is the video.
Mar 29, 2025 at 12:40 PM
TAMBO MOBILES
  • 7 POSTS
Kindly go through the video.
Mar 29, 2025 at 2:29 PM
TAMBO MOBILES
  • 7 POSTS
Thanks sir, it was the front engine mount.
Mar 30, 2025 at 6:39 PM
  • 55,616 POSTS
Thanks for the video sorry for the slow response, glad you got it fixed. please use 2CarPros anytime we are here to help. Can you please leave us a rating?
https://g.page/r/CZdEnyCkGgm6EB0/review
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you
Mar 31, 2025 at 5:05 AM
TAMBO MOBILES
  • 7 POSTS
Bro, also makes clunking sound on left turn and on some bumps but checked ball joint and it was okay.
Apr 1, 2025 at 3:06 AM
TAMBO MOBILES
  • 7 POSTS
Loud sound just like metal breaking on left turn and on bumps but on bumps it's sometime but always on left full turn.
Apr 1, 2025 at 3:08 AM
  • 55,616 POSTS
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Apr 2, 2025 at 3:33 AM
