Grinding noises when put in gear?
2011 FORD ESCAPE
170,000 MILES • 4 CYL • 4WD • AUTOMATIC
JACALF96
Delay between when foot placed on gas pedal or brake about 6-8 seconds. gas pedal has to be pushed hard and car barely moves.
Jul 5, 2023 at 9:33 AM
JACALF96
Car making grinding noise when placed in gear and does not hardly move.
Jul 5, 2023 at 9:36 AM
MATHGEN
  • 128 POSTS
It sounds to me like one of the planetary gearsets has failed inside the transaxle. I've seen this quite a few times in the past. I would take a fluid sample and check it for metallic debris. There is a small drain plug on the bottom of the case. Just drain a small amount, 1/2 cup or so into a clean, dry cup or other container and look for shiny bits. Sometimes shining a flashlight into the fluid sample will help. Please let me know what you find.
Jul 5, 2023 at 11:23 PM
