Grinding noise when the engine is started
168,000 MILES • V8 • 4WD • AUTOMATIC
IDON'TKNOW
Grinding noise when the engine is started and has run for a short time there is a grinding noise. I am wanting to remove the serpentine belt and check the pulley's to see if one of the pulley's is needing replaced.
Feb 2, 2019 at 7:30 AM
SCGRANTURISMO
  • 4,897 POSTS
Hi my name is Alex and I will be helping you.
Without hearing it for myself, I would take an educated guess and say it could be your starter motor dragging.
I am including a helpful link that should take you step by step how to hunt down your vehicles unwanted grinding noise.
Please let us know what you find out. Thanks Alex.
https://www.2carpros.com/articles/vehicle-grinding-noise
Feb 2, 2019 at 11:02 AM
IDON'TKNOW
Thank you for your help!
Feb 3, 2019 at 4:05 AM
