grinding noise when i gas it hard.
141,000 MILES
ACURACL2324
  • 22 POSTS
so every once in a while when i give it more than 50% throttle, it makes this weird grinding noise, and it wont actually accelerate like its supposed to. its not from the transmission, sounds like it could be near the distributor? anyone help me out?
May 3, 2013 at 2:35 AM
DOCFIXIT
  • 18,828 POSTS
Will make noise in neutral rev up engine? Think could be torque convertor?
May 3, 2013 at 2:51 AM
ACURACL2324
  • 22 POSTS
it only makes the noise when its in gear.. and the guy before me put a toggle switch for the torque converter, but i havent touched that.
May 3, 2013 at 5:45 AM
DOCFIXIT
  • 18,828 POSTS
Then I going for torque convertor possible stator bearings
May 3, 2013 at 6:14 AM
ACURACL2324
  • 22 POSTS
is there any way to check for that for sure? without pulling it all apart.
May 3, 2013 at 7:57 AM
DOCFIXIT
  • 18,828 POSTS
drop pan and if lots of metal shavings then thats it
May 4, 2013 at 1:33 AM
ACURACL2324
  • 22 POSTS
okay, and also, when i put it in gear, and go to accelerate it kinda bogs before it actually goes. does that mean intake gasket ? cause thats what i been told.
May 6, 2013 at 3:09 AM
DOCFIXIT
  • 18,828 POSTS
Maybe what did find when droped pan?
Jun 4, 2013 at 1:42 AM
