grinding noise when going round corners and knocking sound from under the bonnet when engine is switched off
2008 CITROEN C1
35,000 MILES
JAYNE WORTHY
weather turning left or right a noise seems to be coming from the wheel area also when the engine has been switched off theres a knocking sound from under the bonnet that lasts for a couple of minutes
Sep 1, 2013 at 4:51 PM
  • 110,240 POSTS
Have you checked the front brakes to see if they are okay? As far as the knocking noise, have a helper turn the key off while you check under the hood for anything loose.
Let me know what you find.
Sep 2, 2013 at 11:35 AM
JAYNE WORTHY
thankyou ive booked the car in the garage so i'll let you know.
Sep 2, 2013 at 7:04 PM
  • 110,240 POSTS
I look forward to hearing from you.
Sep 3, 2013 at 11:14 AM
