Grinding noise coming from passenger side front wheel
2002 CHEVROLET CAVALIER
250,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JACOB UNFEIGNED
There is a grinding noise coming from the passenger side front wheel. The noise only happens occasionally when accelerating from a stop, and always when turning left with my foot on the gas. If I am braking or just turning with momentum of the vehicle then the sound does not occur. I already replaced a CV joint, but it did nothing. When I lifted the vehicle up, and shook the wheel, it was not loose.
Jul 17, 2016 at 2:51 AM
SATURNTECH9
  • 30,869 POSTS
Did you check both sides CV etc.? also have you checked the wheel bearings?
Jul 17, 2016 at 2:57 AM
JACOB UNFEIGNED
No. The sound is definitely coming from the passenger side, people say they can feel the grinding by their feet. And besides checking for play in the wheel, i am unsure how to check the bearings.
Jul 17, 2016 at 3:01 AM
SATURNTECH9
  • 30,869 POSTS
You could have a broken clasped engine or transmission mount.
Jul 17, 2016 at 3:17 AM
JACOB UNFEIGNED
Even if it only does it when turning left? It makes no noise when accelerating while turning right.
Jul 17, 2016 at 3:20 AM
SATURNTECH9
  • 30,869 POSTS
Yes, things shift when turning and hitting the gas.
Jul 17, 2016 at 3:22 AM
SATURNTECH9
  • 30,869 POSTS
I have seen that happen before with only turning one direction and hitting the gas and having that happen.
Jul 17, 2016 at 3:24 AM
JACOB UNFEIGNED
Alright I will try checking it out.
Jul 17, 2016 at 3:28 AM
SATURNTECH9
  • 30,869 POSTS
With that many miles there is a good chance you have more then one bad mount. Rockauto.com has great prices on mounts and other parts.
Jul 17, 2016 at 3:31 AM
