grinding noise
249,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BRYAN P
while starting to drive there is grinding noise coming from where the axles go into transmission.
Dec 21, 2016 at 6:15 AM
HMAC300
  • 48,601 POSTS
it may be a transmission problem so have a transmission professional check that and axles, you may have a bad axle joint.
Dec 21, 2016 at 7:20 AM
HMAC300
  • 48,601 POSTS
also, drive in a circle one way then another and see which way has the loudest noise.
Dec 21, 2016 at 7:21 AM
