Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Sunfire
General
Noises
Grind
grinding noise
2001 PONTIAC SUNFIRE
249,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BRYAN P
MEMBER
1 POST
while starting to drive there is grinding noise coming from where the axles go into transmission.
Dec 21, 2016 at 6:15 AM
HMAC300
Experienced Mechanic
it may be a transmission problem so have a transmission professional check that and axles, you may have a bad axle joint.
Dec 21, 2016 at 7:20 AM
HMAC300
also, drive in a circle one way then another and see which way has the loudest noise.
Dec 21, 2016 at 7:21 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
