Grinding noise
133,000 MILES • V6 • 2WD • AUTOMATIC
GINGANINJA1315
  • 8 POSTS
Recently I have been hearing a grinding noise when driving the car around town, I started thinking it was my struts, but those are fine, now it sounds like a metal grinding noise, which happens when hitting small bumps or turning my wheel. Which leads me to think it is a bad wheel bearing set, bad brakes, or bad CV-joints. I am taking the car into my dealership tomorrow morning. I have had this car for a total of a week, and just started having issues with the car.
Apr 16, 2018 at 9:08 AM
good evening.
If the noise changes pitch while you increase speed or decrease speed, good chance it is a hub bearing. common failure.
if it only happens when turning then it is a CV joint in an axle shaft.
Apr 16, 2018 at 9:49 AM
GINGANINJA1315
  • 8 POSTS
It just makes a weird grinding noise when driving, does not get louder when I speed up, just when I hit small bumps or turn.
Apr 16, 2018 at 9:54 AM
okay, that sounds like an axle.
Apr 16, 2018 at 9:59 AM
GINGANINJA1315
  • 8 POSTS
Now it sounds like it is coming from the front left tire, but I really do not know.
Apr 16, 2018 at 10:01 AM
Yes, the outer CV joint is right there.
Apr 16, 2018 at 10:03 AM
GINGANINJA1315
  • 8 POSTS
okay, another thing is that if I put my hand through the rim and touch part of the wheel bearing, it is extremely warm, it should only be warm, like its way too hot.
Apr 16, 2018 at 10:04 AM
the brakes and the hub will heat up. you should not be able to touch it.
if it were overheated you would notice an issue with the brakes.
Apr 16, 2018 at 10:08 AM
GINGANINJA1315
  • 8 POSTS
okay just checking. well something through my rim gets way too hot, it just seems way too hot to me.
Apr 16, 2018 at 10:09 AM
temperatures run between 150-200 degrees when running for a period. when you stop, it heats up before it cools off.
Apr 16, 2018 at 10:14 AM
GINGANINJA1315
  • 8 POSTS
so it is normal that between the rims is super hot? I know I may be asking dumb questions, but I just bought this car a week ago, and I do not want too many issues.
Apr 16, 2018 at 10:16 AM
yes it will be hot to the touch. you should not be touching when it is hot anyway. even we have to use gloves at times to remove a wheel.
Apr 16, 2018 at 10:17 AM
GINGANINJA1315
  • 8 POSTS
The grinding noise i am hearing is not a constant noise either, it i kind of random as well. would that still be an axle?
Apr 16, 2018 at 10:19 AM
GINGANINJA1315
  • 8 POSTS
So I found out it is just a dry bushing, nothing too bad, car should be fine .
Apr 17, 2018 at 2:10 AM
Good news. something simple. glad you got it fixed.
Apr 17, 2018 at 2:13 AM
