grinding/howling
182,000 MILES
ZACHARY1989
I have a rotational noise coming from my truck. I'm not positive on the location of this problem at this time. I have greased both the inner and outer bearings on the front end. At low speeds it stays at a grinding sound, and at higher speeds 40+ I have a howling noise and a vibration on the floor board.
Apr 21, 2013 at 10:12 AM
you have a bearing failure. did you check the races when you greased the bearings??
Apr 21, 2013 at 10:15 AM
ZACHARY1989
I did, I didn't find any problems when I had it apart.
Apr 21, 2013 at 10:22 AM
