I finally found access to a computer and a getting 'Code 43'. The 'check engine light' is on. Which relates to a faulty Knock Sensor. Apparently someone who had worked on the vehicle previously had broken the Knock Sensor Connector Connector (END). And has taped it into position. The Spark Knock is quite bad & after doing some research, I found the Knock Sensor Connector is part of the EST (Electronic Spark Timing System), consisting of the 'distributor HEI module' and the ECM (Electronic Control Module).
If possible, I would appreciate some direction on 'finding' and replacing the Module, where the Knock Sensor Connector wire is connected. This ( the Knock Sensor Connector) may be the trouble, but I need some help on locating the module and wiring it into the system (wiring harness-Module).
Thank for your time and any assistance in this matter.
T
Friday, July 18th, 2008 AT 10:42 AM
