Grinding coming from driver tire
170,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
OWENJEN95
As tire spins it sounds like something is catching and dragging.
May 16, 2019 at 8:21 AM
Hi Owen,
This could be a number of things but the best way to find it is to raise the vehicle so that tire is suspended and spins freely then spin it by hand and see if you can pinpoint it.
This could be the brakes dragging, backing plate, the shroud, or just something caught between the rotor and pads.
https://www.2carpros.com/articles/vehicle-grinding-noise
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Unfortunately, there isn't one thing I can tell you it it. If you get a recording of it and post it here, I can listen and help limit it down.
May 16, 2019 at 8:34 AM
