Grinding and front tires binding when making sharp turns
237,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
TIMOTHY DOSKOCIL
  • 5 POSTS
Grinding not all the time but grinding and front tires binding when making sharp turns.
Mar 15, 2019 at 1:09 PM
  • 110,248 POSTS
First, make sure the 4wd isn't engaged. When it is on a dry surface, you will feel the steering bind when turning and it will damage different components.
Next, check the front differential fluid to make sure it isn't low. I attached a picture of the front differential. If you look at the picture, number 1 is the drain. Don't remove that unless you plan to drain and fill the differential. However, there is another plug that looks the same located higher on the cover. It is near the number 3 components listed and has no number pointing to it. Once you locate the fill plug, remove it. The gear lube should be as high as the bottom of the threaded opening you removed the plug from. Confirm that.
If it is low, fill it. It requires 75w-90 gear lube.
Last, when you hear this noise, see if anything changes it such as applying the brakes.
Check these things and let me know what you find.
Mar 16, 2019 at 1:27 PM
TIMOTHY DOSKOCIL
  • 5 POSTS
I took it in and had an oil changed and changed fluid on both front and rear differentials. It runs better but the grind is still there. it happens once the brake is applied, feels like a grind and cluck noise.
Mar 17, 2019 at 6:29 AM
  • 110,248 POSTS
Welcome back:
By chance did they inspect both the brakes CV joints on the front axles? Also, did the check for excessive play in the hub bearings?
Let me know,
Mar 17, 2019 at 12:45 PM
TIMOTHY DOSKOCIL
  • 5 POSTS
No, i just had the fluid changed i am going to another shop to have it gone through.
Mar 17, 2019 at 3:21 PM
  • 110,248 POSTS
Welcome back:
If it seems to be related to the tire rotation, then my guess is it is one of the things I mentioned. Let me know what you find or if I can be any help.
Mar 18, 2019 at 9:56 AM
TIMOTHY DOSKOCIL
  • 5 POSTS
Had the front brakes replaced rotors pads and brake limes, but it is still doing the grinding noise but not as bad. the shop said everything was fine.
Mar 22, 2019 at 9:12 AM
  • 110,248 POSTS
Tell me something. Does it matter if you turn left or tight to produce the noise? Do you hear any howling noise when driving straight. If it is grinding, I can't believe they said it's okay.
Mar 22, 2019 at 1:59 PM
TIMOTHY DOSKOCIL
  • 5 POSTS
Driving straight there is no noise at all it doesn't howl or anything. it grinds when braking and feels like the tires are going to fall off if i make sharp turns like a u turn or pulling into my driveway.
Mar 22, 2019 at 4:05 PM
  • 110,248 POSTS
Timothy:
It has to be related to either a hub bearing or something with the axle. My first suspect is a hub bearing since the noise is heard on turns and braking. Do me a favor. Safely lift and support the front of the vehicle. Place your hands at 12 and 6 oclock. and wiggle the wheel back and forth checking if you feel a clunk or if there is noticeable play. Also, do the same thing at 3 and 9 oclock to see if you feel anything. It shouldn't be grinding. Especially if brakes were just done.
Here are the directions from the manual for checking. The three attached pictures correlate with these directions. Also, the last picture shows bearings for both 2wd and 4wd. Your vehicle will have the sealed wheel hub bearing.
______________________________________________________
Raise the vehicle until the front tires are off the floor.
Make sure the wheels are in a straight forward position.
pic 1
2. Note:
Make sure the wheel rotates freely and that the brake pads are retraced sufficiently to allow free movement of the tire and wheel assembly.
Spin the tire by hand to check the wheel bearings for roughness.
pic 2
3. Grip each front tire at the top and bottom and move the wheel inward and outward while lifting the weight of the tire off the front wheel bearing.
pic 3
4. If the tire and wheel (hub) is loose on the spindle, does not rotate freely, or has a rough feeling when spun, carry out one of the following:
On vehicles with inner and outer bearings, Inspect the bearings and cups for wear or damage. Adjust or install new bearings and cups as necessary.
On vehicles with one sealed bearing, install a new wheel hub. Refer to the appropriate workshop manual for the service procedures.
Let me know what you find.
Mar 23, 2019 at 10:44 AM
