grind/whine noise coming from clutch or tranny on take off... sound goes away once im going and gears shift perfectly besides quick thud of gear engag
130,000 MILES • 2.5L • V6 • RWD • MANUAL
ARBERY1992
my clutch went out about two weeks ago... tranny was fine before.. got car back from mechanic.. when its in neutral idol.. i hear a small ticking noise. when i put in gear and depress clutch it grinds/whines until i get to a good rolling speed. what could this be??? flex plate??? throwout bearing??? idk
Oct 12, 2015 at 6:55 PM
WRENCHTECH
  • 20,760 POSTS
Could be a problem with the clutch parts or installation. Could be the hydraulics still have air in the system. Either way I would just bring it right back to the shop that did it.
Oct 12, 2015 at 7:16 PM
ARBERY1992
It took them 2 weeks to give me back my car and they admitted that they didn't know what they were doing and had to contact bmw several times.. over a clutch installation?? I'm pretty handy when it comes to cars and can fix most problems just need to know from a professional opinion.. is it most likely a throw out bearing?
Oct 13, 2015 at 6:27 AM
WRENCHTECH
  • 20,760 POSTS
The solution will be found through examination. The transmission may have to come out again so they should be responsible.
Oct 13, 2015 at 6:29 AM
