Check engine light keeps coming back on after work is done
195,386 MILES • 6 CYL
JOAN JAMES
  • 23 POSTS
Check engine light keeps coming back on after work is done when I get to 50-60 miles on it. my mechanic has changed all four sensors, crank position, coil pack, almost everything is new. the code that keeps coming up is bank one while the computer is on it and he gives it gas the numbers drop down low.
Apr 7, 2019 at 10:40 PM
CARADIODOC
  • 34,414 POSTS
The most common mistake is thinking diagnostic fault codes say to replace a part or that one is bad. In fact, they never do. Fault codes only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. Many people replace oxygen sensors when they report a bad condition, but in reality, the sensor has to be good and working properly to detect and report that bad condition. Changing a sensor won't fix what is causing the problem.
The first concern here is we need to know the exact fault code number. Your Engine Computer can detect well over 2,000 defects. There can be over a dozen fault codes pertaining to just one of the oxygen sensors, and they mean very different things. Once we know the code number(s), we can figure out how to proceed.
Please list the engine size too. We use that information when diagnosing engine-related problems and suggesting the most common suspects.
Apr 8, 2019 at 11:41 AM
JOAN JAMES
  • 23 POSTS
Engine size is 2700cc 6 cylinder OBDII, evap.
Apr 8, 2019 at 11:22 PM
CARADIODOC
  • 34,414 POSTS
Dandy. The "OBD2" just means the car has "on-board diagnostics, version 2" emissions system. All cars and light trucks sold in the U.S. starting with 1996 models have that.
Here's a list of the generic fault code numbers we use for reference:
https://www.2carpros.com/trouble_codes/obd2/p0100
Not all are used by every manufacturer on every car model. There's also a lot of manufacturer-specific codes over 2,000 now too. When you're told the fault code number, it may start with a "P", such as P0442. That is for a power train code, meaning it's stored in the Engine Computer.
Apr 9, 2019 at 10:29 AM
