Got spark from coil but only spark on number one plug wire. no spark on two, three, four cylinders. replaced plugs, wires, cap, and rotor.
Apr 22, 2018 at 6:44 AM
KHLOW2008
✓Experienced Mechanic
This is most likely a fault with the cylinder position sensor. The No 1 plug is able to fire because the TDC sensor (which is set at cylinder 1) is working and providing the conditions for the spark to occur then. Have the CKP sensor tested. You should have the Check Engine Light on with trouble codes stored in ECU.
Apr 23, 2018 at 6:38 PM
CHARLIE CLARK
MEMBER
How u check codes on a 1991 2.6 amigo
Oct 1, 2018 at 3:07 PM
Please post your new question here, you must be logged in.
