goes thru about 3 qts of oil per month
72,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PWJ41192
My son just bought an 03 cavalier 2.2 engine .It runs smooth, but now that its getting cold ,I noticed this morning that the exhaust is blowing light blue smoke.. There is no service engine light coming on, & it gives me no codes on my scanner. Is it worth repairing ? Or should I do the head, or rings??
Dec 4, 2014 at 9:51 AM
BLACKOP555
  • 10,386 POSTS
blue is oil as you might have figured already. does it do it initially when started and clears up or is it all the time. if its only on start up. suspect valve guide or seal issues causing leak. if it is all the time or worse when accelerating suspect worn piston rings or cylinder walls.
Dec 4, 2014 at 10:16 AM
