There is no check engine lights and all the gears it goes into, you can feel. When o.j. t is put into first it'll drive if you rev the RPM up and it'll jump forward and if you put it into reverse it will try but wont move only nudge backwards a bit and if the tires are lifted up it continues to have trouble. The transmission pan was leaking and i filled up to the top and did exactly the same thing it did when it was low on transmission fluid. I am at a loss on what could be wrong.
Mar 2, 2019 at 12:56 PM
