Where is the CAM shaft position sensor located?
200,000 MILES • 1.6L • V8 • 2WD • AUTOMATIC
JLWHIT
Where is the 2004 Lincoln Aviator CAM shaft position sensor located?
Jan 18, 2025 at 7:02 AM
CARADIODOC
  • 34,414 POSTS
The only engine used in 2004 was a 5.4L. This drawing shows the sensor locations.
Jan 18, 2025 at 8:06 AM
JLWHIT
CAM shaft position sensor location needed.
Jan 20, 2025 at 4:13 AM (Merged)
  • 110,248 POSTS
It is on the driver's side front of the engine, mounted in the cylinder head. You need to remove the power steering fluid reservoir and its mount to access the sensor.
I attached a picture and directions below. Pic 1 is just to give you a general location. Pic 3 provides a better view.
JLWHIT
Concerning my 2004 Lincoln Aviator, your advice was perfectly spot on. However, I am experiencing trouble removing the power steering fluid reservoir mount. Can you provide instructions for the removal of the mount?
Feb 26, 2025 at 4:51 AM
CARADIODOC
  • 34,414 POSTS
Here's the procedures for the cam sensor and the power steering pump, but nothing is shown for the reservoir. They just show it should take 0.8 hours. Joe may be using a different reference source. He will post more information if he has it.
Update: I found this last drawing under "Front Cover Removal". It may help by showing he bolts for the bracket.
Feb 26, 2025 at 10:06 AM
JLWHIT
Have you instructions on removal of the mount (bracket)?
Feb 26, 2025 at 12:03 PM
