Where is the blower motor?
PULSTI
  • 28 POSTS
I don't have the owner's manual and from what I've read on other's forums, I should check my blower motor but; 1. Can't locate it. 2. Don't know how to test it? The vehical is a 94 GMC Yukon. Thank You.
Jan 28, 2006 at 1:37 PM
SCARBER
  • 6 POSTS
The blower motor is usually on the passenger side behind the glovebox. There will be a small guard with 4 or so bolts covering it and sometimes the heater core.
Jan 29, 2006 at 10:15 AM
GREASEMUNKE
  • 35 POSTS
Whats the problem first off.Your blower motor will be behind the dash from the middle console over towards the glovebox.You can usually tell where it is by sight.There is not always bolts to remove a blower motor .You might have to cut the plastic housing to reach it.
Jan 29, 2006 at 4:57 PM
