SOLVED: Rough idle at startup in cold weather
BUNGNATI
Solved!!!
The intake manifold gasket was bad. Replaced them and runs fine in cold weather.
GM is aware since they issued a TSB about it PIP3232B
Dealer wanted $700 to replace it. Did it myself in 4 hours for $45.
Hope this helps.
I have a 2001 Yukon XL 1500 5.3l 323 cid with 103,000 miles. Recently I started the truck in 15F and idled very rough shook the truck and everything. Tried giving it gas and it wanted to stall when I did. The MIL started flashing then went out.?. The truck ran perfectly when it warmed up alittle. This happened the next day 25F but not as bad or for as long. I also had the computer throw a Evap code 3 days before and a similar evap code about a month ago. Now I started it at about 50F and started and ran fine. All sensors are reporting to the computer and seem to react properly by the OBDII scanner at 50F (dont know about colder temps yet)
Any help would be great.
Thanks,
John
Nov 27, 2007 at 3:07 PM
  • 75,988 POSTS
Won't hurt to check the TPS its job is to enrich fuel during initial cold starts it takes the place of a carb. choke Might also want to investigate the IACV.
Nov 27, 2007 at 4:30 PM
BUNGNATI
Wouldnt the IACV cause other idle problems even when engine is warm? The TPS seems fine it detects even slight movements of the throttle and I have read the sensor data with the obd port. I also saw a post about a sierra 5.3l with similar problem
https://www.2carpros.com/forum/gmc-sierra-1500-4x4-rough-cold-start-in-cold-weather-vt70029.html
does the responder mean the IACV.
Thanks.
Nov 27, 2007 at 5:05 PM
JEFFSWANSON
Did you ever get your problem fixed? Our 02 Yukon is experiencing the same problem. Our mechanic wants to replace the intake which is made of plastic. Warm weather idles great... Cold weather idles very rough.
Jan 3, 2008 at 8:22 AM
