Rough idle, spark knock
GOODFELLA937
Installed new intake gasket, along with a few other gaskets on 1995 5.7L yukon. Engine has very rough idle , pings under load. Possibly EGR?
Oct 20, 2007 at 11:03 AM
BLACKOP555
  • 10,386 POSTS
make sure parts where you installed gasket are tightend securley.
did this happen afte rhte gaskets are before?
Oct 20, 2007 at 1:57 PM
GOODFELLA937
Tightened everything to spec, just started this after I completed the job. replaced spark plugs and vacuum lines.
Oct 21, 2007 at 3:36 AM
BLACKOP555
  • 10,386 POSTS
go back over everything. did you apply gasket sealer to the gaskets?
Oct 21, 2007 at 12:31 PM
